nitinat forecast
nitinat forecast
Hi folks,
Was thinking of heading to nitinat camping tomorrow a staying for a couple of days. The forecast looks pretty bad. Just wondering when it's cloudy/rainy, is there likely to be zero wind or just gusty unpredictable wind?
Thanks,
Thanks,
Hey,
Thanks for the reply.
Yeah, I'm going on a camping trip with some friends who are visiting from overseas. Camping somewhere on van island is definite but not all of them kite so nitinat in the rain with no wind isn't really ideal. Columbia beach looks like a decent alternative. Although what makes you think that there should be ok wind? Windguru forecast isn't too promising.
The other option I was considering was China beach closer to juan de fuca but seems unlikely to be any wind there either.
local forecast: http://www.bigwavedave.ca/forecasts.php?page=1
Tues/weds/thurs all look good in comox / parksville area.
Pool your $, stay in somewhere with a roof and hot tub.
camping options around there...though probably not very wilderness style
http://www.comoxvalleychamber.com/RV-ParksCampgrounds
better bring some water
check it http://www.bigwavedave.ca/webcams.php?cam=13
Never been to Nitinat before but looking at Fri, Sat and Sun (July 5, 6 and 7).
Is a temperature difference of 6C, 8C and 4C between Tofino and Port Alberni sufficient for wind? Or do I have it wrong?
See http://wind.altoning.com/temp?station=B ... C/s0000496
6 and 8 Tdelta should be fine, so long as there isn't an easterly pressure gradient, and so long as the coast doesn't stay clear and overheat. 4 degrees is getting small, but doesn't mean it won't blow, but likely to be a big gear day. A beach forecasting discussion on the weekend with a few centuries of combined experience represented was: "If you are here and its windy, then its windy; if you are here and its blowing hard, then its really windy". In other words, just go, hang out, multi-day skunks are rare in summer (maybe not this year so far.....)
Excellent. Temperature differences looking even better 5, 8 and 9 C (Tofino to Port Alberni Fri - Sun).more force 4 wrote:6 and 8 Tdelta should be fine, so long as there isn't an easterly pressure gradient, and so long as the coast doesn't stay clear and overheat. 4 degrees is getting small, but doesn't mean it won't blow, but likely to be a big gear day. A beach forecasting discussion on the weekend with a few centuries of combined experience represented was: "If you are here and its windy, then its windy; if you are here and its blowing hard, then its really windy". In other words, just go, hang out, multi-day skunks are rare in summer (maybe not this year so far.....)
See http://wind.altoning.com/temp?station=nitinat
Can we infer a favourable pressure gradient from the GFS models for Long Beach and Nitinat (Fri Jun 5 to Sun Jun 7)?
Weather producing marine layers like this: http://www.atmos.washington.edu/cgi-bin ... cgi?vis1km bring the best days. Just go. you will enjoy it
Thanks JL. I added a satellite link to http://wind.altoning.com/temp?station=nitinat. I've been told a S, SW and W direction on WindGuru is favorable. Looks like I'm going to pull the trigger.
I'll bring some (4.7+5.2/93L) windsurfing gear but my goal is to learn to kite upwind (7m, 9m and 11m) this weekend (Fri to Sun).
