Looking for 2 M8 x 23mm bolts
ColdSnap
Been thanked: 4 times
Unread post by ColdSnap »
I'm trying to find 2 bolts for a Slingshot Hoverglide foil system. They are the ones that go through the front wing and fuse, and hold on the mast cap, when the foil is set up in the B position.
They are M8 x 23 mm.
I've found them at a store in Toronto but I'm trying to avoid paying $20 for shipping for 2 bolts! I'd prefer stainless but I'm fine with Ti as well.
Please let me know if you have any ideas.
John
Murch
Re: Looking for 2 M8 x 23mm bolts
Unread post by Murch »
I've had luck with Fastener Force right here in Victoria for replacements.
ColdSnap
Thanks for the help - I found what I needed at Fastener Force.
