Wing Gloves - Winter
slake
Has thanked: 10 times
Unread post by slake »
Has thanked: 15 times
Been thanked: 29 times
Re: Wing Gloves - Winter
Wings:Duotone Unit 3.0-5.5m;
Has thanked: 27 times
Been thanked: 15 times
Unread post by Bobson »
ps. I do secretly wish I could Wing. Maybe, one day. :-$
Highrocker
Has thanked: 13 times
Been thanked: 26 times
Unread post by Highrocker »
The following applies:
Warm wingfoil wishes.
velcro elastic cinch straps
https://www.amazon.ca/gp/product/B097BG ... UTF8&psc=1
https://www.amazon.ca/gp/product/B0964D ... UTF8&psc=1
TunaCan
Unread post by TunaCan »
MtnarG
Unread post by MtnarG »
Gyro Beach Board Shop only has the NRS Mitts in size XS
slake
slake
jessematthewman
Unread post by jessematthewman »
jessematthewman
Annnnnd looks like vissla stopped making the 1.5mm. Lame. It was (is) honestly the most durable thin wetsuit glove i’ve ever owned and it only has one repair after a full year on the water, and that’s from scuffing my knuckles on some barnacle… :(
Unread post by smartang »
slake
UnusuallyLargeRobin wrote: Mon Nov 20, 2023 8:47 am I am about to receive these Ion glove/mitts
slake
