El Nino / La nina / Neutral
http://www.cpc.ncep.noaa.gov/products/a ... disc.shtml El Niño is expected to form and continue through the Northern Hemisphere winter 2018-19 (~90% chance) and through spring (~60% chance).
El Nino 2019.PNG (61.03 KiB) Viewed 10383 times
El nino map.PNG (256.42 KiB) Viewed 10381 times
Well we now know that the el-nino model of a warm Jan. to March can be interrupted by an extended arctic air outbreak complete with record snowfall :? Having said that here is the latest update: https://www.cpc.ncep.noaa.gov/products/ ... disc.shtml
3 month precip..gif (33.27 KiB) Viewed 10246 times
3 month.gif (33.86 KiB) Viewed 10246 times
2019 El-Nino.PNG (61.93 KiB) Viewed 10007 times
Synopsis: El Niño is likely to continue through the Northern Hemisphere summer 2019 (70% chance) and fall (55-60% chance). https://www.cpc.ncep.noaa.gov/products/ ... disc.shtml
El Niño is predicted to persist through the Northern Hemisphere summer 2019 (66% chance), with lower odds of continuing through the fall and winter (50-55% chance). https://www.cpc.ncep.noaa.gov/products/ ... disc.shtml 8)
A transition from El Niño to ENSO-neutral is expected in the next month or two, with ENSO-neutral most likely to continue through Northern Hemisphere fall and winter. :shock: https://www.cpc.ncep.noaa.gov/products/ ... disc.shtml
El Niño has transitioned to ENSO-neutral, which is most likely to continue through Northern Hemisphere winter 2019-20 (50-55% chance). https://www.cpc.ncep.noaa.gov/products/ ... disc.shtml
https://www.cpc.ncep.noaa.gov/products/ ... disc.shtml ENSO-neutral is favored during the Northern Hemisphere fall 2019 (~75% chance), continuing through spring 2020 (55-60% chance).
ENSO-neutral is favored during the Northern Hemisphere fall 2019 (~85% chance), continuing through spring 2020 (55-60% chance). https://www.cpc.ncep.noaa.gov/products/ ... disc.shtml
ENSO-neutral is favored through Northern Hemisphere spring 2020 (~60% chance), continuing through summer 2020 (~50% chance). https://www.cpc.ncep.noaa.gov/products/ ... disc.shtml
ENSO-neutral is favored through Northern Hemisphere spring 2020 (~60% chance), continuing through summer 2020 (~50% chance). ... https://www.cpc.ncep.noaa.gov/products/ ... odisc.html 8) https://cliffmass.blogspot.com/2020/02/ ... -nada.html
