Willows web cam
right on, maybe you wanna be part of our team thenscott c wrote:great website , I use it daily.
http://www.bigwavedave.ca/donate.htm even small stuff all helps
apparently the angle is such that to be in pictures you need to go almost to the point to make the record, I gybed in the normally best wave area only to make it barely into the frame, might need a wideangle on there afterall
- Has thanked: 40 times
- Been thanked: 57 times
It got blurry a bit on Friday because of rain hitting the window (the camera is indoors). It's a fixed focus camera (no autofocus), but the rain on the window makes it look blurry. I do have an outdoor enclosure for it that has a bit of a hood which might help with the rain and would also give us more choice in viewing angle. Not sure when we would install that though...it looks pretty good to me
The focus does need to be tweaked a bit. It's a zoomable webcam but right now its only focused on the wide angle and it needs to be fixed so that it works for all zoom levels. But it means spending an hour or so with the camera...one day. We don't want to wear out our welcome there either.
